- Dec 2, 1999
I would like to make my own stencils but I dont know what software a dummy can use to make the original. Anybody with experience with this? Remember key word "dummy"
Bruce, if you'd like, i can bring my laptop with me the next time i'm in walla walla and work something up for you. I'm a pro and it wouldn't cost you anything. I have to come down to have my wife's rig worked on at the old man's shop in the next couple of weeks. be my way of paying back your kindness. if you're stuck on doing it yourself, i can assist you if you like.
Heath
509-385-1437
Hi Bruce,
I just used MS Word when I made mine.Any program you can print from will work. But some fonts are more successful than others. Some just make stencils that are too fragile. because of insufficient support around the letters. Make sure to get the correct kind of transparencies for your printer. The first ones I tried were an exercise in frustration. Then I found out they were the wrong ones, got some for an inkjet from Staples (they have small packages available) and then had good success.
Good luck
Alden
Bruce are you looking to just doing the art work for a stencil maker
or looking to make the stencils also?
Bruce I am using Corel Draw to do the art work on the stencils I make. Using it makes controlling the size of the actual stencil lettering easy. I generally call out the length I want (and that is usually 3/4" long) and it prints out the font lettering exactly 3/4" long onto the transparency. Another thing I do Bruce is when I lay the transparency w/ the printed art work on the light box, then the film on top of that I have a little piece of 1/4" plywood that has a piece of black felt tack glued to it on top of the film. The piece w/ the black cloth on it helps to prevent any light leakage and helps keep the stencil lettering nice and crisp. When developing the stencils and you are washing them I also like to take the air hose w/ a blow gun on it and blow any remaining undeveloped film away. Again it helps, especially w/ any small lettering or lines that are hard to clean out.
Gentlemen,
Are there any tutorials on this process? Also, what is the equipment that is used.
Ickie
