I've posted a couple threads already about making my first knife so some of you may have seen some of this same stuff from me. Sorry for being repetitive. I'm not actually making the knife, I'm just assembling a knife kit so I'll just be attaching the guard and making the handle. My kit arrived in the mail yesterday so I'm going to take my time to make sure I get it right, and get it put together over the next couple weeks.
For the handle I'm most likely going to use some black walnut that my uncle has in his woodshop. The wood has been sitting a while so it's good and dry so that won't be a problem I'll run into. I will have to stabilize it though which I'm going to do myself because it is more cost efficient and I'm just trying to make a simple hunting knife. I think I have the entire process down in my head but I just wanted to post a step-by-step list of what I plan on doing to see if I have it right. Any input, suggestions, and/or possible changes are welcome. Thank you!
Cut wood to scale size and stabilize.
Attach guard by peening the ends of the pin over. File the ends of the pins so that everything is flush.
Trace tang shape on scales and cut them a little larger than the tang size to allow for sanding and shaping.
Clamp knife to the scale and drill pin and thong holes through the scales. Repeat for the other scale.
Attach the scales with the pins (no epoxy) to make sure everything fits good.
Sand and shape handle to my liking.
Take the handle apart and put epoxy on the entire tang, inside of the handle, and pin and thong holes.
Attach handle.
After the epoxy dries do what minor sanding is left, polish the guard and handle, coat the handle in boiled linseed oil.
Kill a deer.
Field dress the deer with my new knife.
Attach handle.
Kill a deer.
