Stick Tang - Tools
driezeinaz
Dry Creek Bladeworks
I have seen some guys with custom tools for hogging out wood handles for stick tang blades. Does anyone have a source for these? Here is a pic of a fellow maker that had one. Also, any good files (size or manufacturer) that are useful for removing material when doing stick tangs. Thanks all!
James
West Bench Blades
Riverton, UT
You can fashion a broach out of sawzall blades and a course cut round file. They both can be ground to fit your needs.
If you look at the design, those broaches are extremely simple. One could be made easily using a piece of steel. The teeth on the broach in the pic you posted look like small pyramids. I would personally rather have them with one side(the side facing the handle) being flat. If you do a search on these forums for "broach" you'll find a bunch of pics of good designs.
You wouldn't really even need to make a handle for it and just use a file handle.
I made one out of hacksaw blades but will probably make a better one out of 3/16" stock soon.
Will your tang will protrude thru a pommel ?
I may use the prior mentioned broaches to square up a hole,
But it gets roughed out using one of those round grit embedded hacksaw blades.
Usually I just rough out the tapered hole oversize,. Let epoxy fill in the voids.
It won't extend through a pommel. Thanks for the tips.
Thanks. I will just try and craft something, the Bruce Bump version is $76. I have enough saw blades and scrap metal that I could fashion something.
I make my own as well. Start with a small round bar and heat the end in the forge. Fold over an inch or so and forge weld. Square everything up and cut teath into it with a thin blade on the angle grinder.
I built one out of a scrap piece of 3/32 154CM stuck into a piece of 3/4" dowel rod. Did cryo and a low temper (400 or so). Dirt simple, cuts very well.
