I got an 0560 today and it's perfect. Not sure if this is a new batch or something but everything on it is just right.
I read somewhere on the newer zt056x's they carbidized (sp?) the top of the lock bar that makes contact with the blade. My 0561 has a fairly low serial number (712) and it doesn't stick at all though. Not sure exactly when they started doing that.
THe 0560's have always been carbidized.
Really? I thought you could actually see this after its layered on the lockbar. Mine doesnt seem to be carbidized. And also I saw a youtube video of someone carbidizing their 560 and it looked a lot different as he was doing the process. Maybe he does it a different way?
As said you cant compare a 560 with a 350. The 350 has a torsion bar that aids in the deployment of the blade. A 560 has bearings in the pivot and a stronger detent yet has no or torsion bar whatsoever. It is quite possible that a couple of the pivots were too tight but if properly adjusted these knives are as fast or even faster than an automatic. But the only caveat is there is a technique to deploying the blades in a way that will get them to snap with authority. The best way I can describe it is to build up energy on the flipper by stiffening your finger almost like how you build up energy in you fingers if you are going to snap them. A good way to do this is to actually apply force to the flipper in the opposite direction or in towards the handle so that your building energy but not moving the blade. Then when you have as much energy built up as you can develop redirect the direction of said energy and the blade will fly out with authority. A couple things you need to understand
1. The thumbstuds are not really designed to open this knife. Its is designed with using the flipper. The thumbstuds shouldnt really be looked at as such and rather as a blade stop for lock up.
2. Another thing that can screw up a good deployment are your other 3 fingers when your firing the knife. If your have a iron death grip on the knife and those fingers are on the lockbar you are actually pushing the detent forcefully into the blade and this can either prevent the blade from opening or it can actually slow the blade after its deployed. There is a small learning curve with these knives but once you master it you probably will like them more than an assisted knife. Especially since there are no torsion bars to wear out.
Picked it up on the way home. Love this thing. I got the smoothest one he had. What a knife. Unfortunately he showed me the ZT0303 while there so my next purchase may already be a done deal.![]()
I don't even have to use any wrist action to open my 560,it came from the factory that smooth. I love it!
my roomate's aunt makes $83/hr on the laptop. She has been without work for 8 months but last month her pay was $8682 just working on the laptop for a few hours. Read more on this site...NuttÿRîçhDÖtcom
