Understand the this machine is not mine and it is set up to weld automotive body panels, etc.
Just tell your buddy you need to crank it way up. They should be able to accommodate that unless they have no idea how to weld and just found a setting that works. If it starts sputtering, and not holding arc, then you need to crank up the wire speed. Worst case, mark the wire feed knob setting they use with a sharpie, and the voltage if necessary, and you can set it right back where they had it.
If it's being used indoors, and they have shielding gas hooked up, it shouldn't be flux core or anything wonky. Although, if it's being used outside, there is a chance that it's flux core and they're running shielding gas, if so, that could cause an issue. My guess though, is that it's just ER70S-6 (carbon) wire, and 75/25 or similar Argon/co2 mix gas, which is good for 90% of general steel welding. Just crank it up.
Yes, pre-heat is advantageous if you're trying to make structural welds with high carbon. Is it "better" ? Sure. All we're saying is, in the interest of expediency, and trying not to over-load the OP with "best practice theory", is that it isn't remotely mandatory in this case. A couple of us here have made more billets in the last year that most of you will in a lifetime, Devin especially, no offense intended to anyone, but trust us, it's not necessary, unless it's a really weak welder. Frankly though, any 220V mig welder on the market, cranked up to a high voltage, should be able to handle this task. Or hell, don't believe us, no skin off my back.Just like the whole TIG welding dry stacks issue, those of us that do this for a living, have learned, there are quicker ways to skin this cat, which yield functionally as good results, with much less time and labor, even if it isn't quite as good; "on paper".
If jdm is really interested in learning to weld properly, that's excellent, it's certainly a worthwhile pursuit, but I'm getting the impression he just wants to be able to tack billets together, not worry about the handle falling off, and has very little interest outside of that.
Also, don't obsess over the "stacked dimes" aesthetic, it's very contentious whether this actually produces a better structural weld with GMAW, compared to a continuous, smooth bead, with proper penetration (robotic welds that are perfectly calculated, and tested, never look like this btw), compared to TIG welds, which *should* look this way, based on how the filler is applied. Honestly it seems to have become an expectation primarily as a by-product of the "tig weld as art" phenomenon perpetrated by such things as the custom "chopper" bike scene, and trying to imitate that. Somehow, it's become a myth that it's necessary for mig welds, but there's plenty of science that shows that not to be the case. Does it hurt anything? Probably not, but there have been tests showing stacked dimes mig weld beads failing before properly penetrating deep concave smooth continuous beads. Heavy spray transfer welds, will never look like stacked dimes, and have the best single pass potential strength on thicker stock. Ok, I digress.
The MIG-LIKE-TIG stack of dimes is a weaker, lower penetration weld than a smooth bead.Just tell your buddy you need to crank it way up. They should be able to accommodate that unless they have no idea how to weld and just found a setting that works. If it starts sputtering, and not holding arc, then you need to crank up the wire speed. Worst case, mark the wire feed knob setting they use with a sharpie, and the voltage if necessary, and you can set it right back where they had it.
Simple answer: Turn up the amperage and/or turn down the wire feed. It sounds like you have penetration issues, which to me means more amperage. One thing that can affect penetration is amperage, but I've also learned that the distance of your nozzle from the weld will make a big difference in terms of penetration. The closer I can get my nozzle to a weld, the better the penetration will be. If I hang the nozzle back too far, the wire seems to melt before welding occurs. You want the wire to be pushing down into the material.
I would first try to address the penetration issue. If you can get good penetration and you're still getting beading, then you need to turn down the wire speed. I can easily weld a piece of rebar onto a billet using my poor little Lincoln HD125 (probably their smallest machine). As others have pointed out: proper prep (chamfering your bar) and preheating can all help out.
Okay but my dad is much more impressed when my welds look prettyThe MIG-LIKE-TIG stack of dimes is a weaker, lower penetration weld than a smooth bead.
I am a full time certified welding inspector and have been a welding instructor as well as welder for 20 years with certs for GMAW, GMAW-P, GTAW, SMAW in steel aluminum and nickel alloys. The biggest thing I have learned is that I still have a lot to learn. Most of these techniques have a context and are not totally right or wrong. Stacked domes techniques come from using electrodes like 6010 or old school spray arc aluminum where the arc is really to hot to hold in one spot so its swept forward and then brought back to add some fill on top of the the cooling puddle. When used like this it is not wrong. Because it looks cool some places do it for looks. If done well there is still nothing wrong with it. It can be a problem if the puddles are spaced to far apart with to fast travel speeds. This can lead to some non fusions and sometimes pinhole porosity from the non filled center craters. It can also lead to a inconsistent weld bead with stress risers. Because of this some condem the technique and want the weld to be performed with no oscillating motion. This can also be problematic especially with non fluxed electrodes as surface tension can be a issue. This can lead to a very tall domed weld bead that is difficult to control and does not wet out well. Even small movements can help with this because the arc force pushing on the puddle will force metal to the toe and help with wetting as well as providing a larger weld deposit. Even when the stacked weld is being done for aesthetic reasons good technique can give a sound weld. I have qualified welding procedures using a somewhat stacked appearance and had them pass easily.
Also the term weld strong not pretty doesn't really provide the best advice since a weld that is free of flaws tends to look good.
You already weld as a Smith and know what makes a good weld. If you can just visualize that and then look at your welding equipment you know what has to happen. On some scrap or something as thick as what you are trying to weld make sure you can get a puddle. If not turn up the machine. You are going to have to weld slower and more deliberately than you think. So long as you can see the puddle you are welding. One way to know if both sides have fusion is to watch them cool. They should cool from the outside to the middle. If a weld toe stays hot it is not fused.
If you are still having problems send some pics for us to troubleshoot.
Well, welding a handle on, isn't what he's having a problem with I think, it's having it survive drawing out and/or restacking. Just getting a handle stuck on isn't usually an issue, but having one that'll survive multiple restacks, is usually tricky for most. Whenever I'm making damascus in a friend's shop with other experienced makers, there's an inevitable process of "tacking the handle back on", at very least, during restacks, and occasionally, mid-session, before restack. The handle transition area takes a lot of abuse, especially when drawing out billets on a power hammer, it's the main area of temperature differential between the hot billet, and the cool handle, and a concentration area of vibration and leverage, on top of being a change of base materials, and dimensions. It makes sense, and you've gotta have a strong weld with lots of penetration and material to compensate.
