I have an evenheat kf27 kiln.
I have tried to HT 1075, 1084, 80Crv2, and 5160
Basic Protocol:
I've been soaking at 1500 for 10 min, then quenching in 3 gallons of canola oil heated to 140F.
1075 has reached max hardness 64HRC
5160 has reached max hardness 64HRC
80Crv2 lands consistently at 54HRC
1084 has never been above 40HRC
All my results have been inconsistent but these are the best.
All the Steel varieties reached full hardness when quenched in 8% brine. Then they promptly fractured.
I've tried canola oil, vegetable oil, corn oil, water, brine, interrupted quench. 1475F, 1500F, 1520F, 1550F, 1600F, 1650F before quench. 3min soak, 5 min soak, 8 min soak, 10 min soak.
I've normalized before quenching, and I've tried repeated heat and quench cycles back to back.
I've ground down .060 to see if it was the same HRC through and through (it was).
I've tried letting the steel cool in the oil, in the air, and water quench after oil.
One experiment involved 4 identical 1075 tokens (notched for id purposes). Each was quenched at a successively higher temp. Then one quenched at 1500 hit mid 40's HRC, 1550 was Full hard at 65HRC, 1600 was 61HRC, and the 1650 had some spots at 61 HRC and some at mid 50's.
Is there anyone in Utah near SLC that has successfully treated these steels? If so come to my shop and show me what I'm doing wrong. I'll buy you lunch.
I'm guessing that I'm doing something fundamentally wrong or there is a serious flaw with my setup.
Basic Protocol:
