- Jun 3, 2019
Glad you got holes in your blade.
Interesting experience. Went back to my bench to complete the rest of the blades, and noticed that there was steel melted into the flute of the drill bit. That bit would not cut again, and was toast after 2 holes (and a time delay after). Seems to me that doing this relies more than a little bit on heat. Run the bit until the steel below heats up and softens and the bit starts cutting. dont stop (keep the heat on) until the hole is through. I then did my best to wipe crud off of the tip with a wet paper towel, shift to the next hole as fast as reasonable. rinse and repeat. Got six holes done with that second bit. Last hole cut almost as well as the first. I will lay odds that now, with a time delay, the steel in the drill bit tip has hardened, and that second bit is now useless (would test - but I do not have any more blades to drill
If this is the case ... that then makes sense of what others have said: dont use too high a drill speed (will burn the bit), not too slow (wont generate enough heat?), medium pressure, etc. seems to make sense in that light.....
