Still searching for the hamon
I have a few attempts at the hamon line, without success. I am beginning to think it is my blade. I am trying the forged 52100. I can see the line after heat treat but after I do the final grinding it disappears. I followed the guidelines posted by Ryan W Knives but no luck. I have used both Ferric Chloride and hot vinegar.
Is it the steel or am I still not doing the right procedure?
Are you edge quenching? or a total quench? quenching the entire blade? To get a hamon, you must either use a clay hardning technique, or edge quench; i.e. heat up just what's to be the cutting edge, and then quench the entire blade. When you use the edge quench technique, you get this:
[/url]DSC09749
This is a little 4" puukko I just made in 1095 and it's been edged quenched. Here's some more pix of the little knife, had I dipped it out in feric chloride, it would really stand out.
A little slide show, you can see the hamon more clearly is some of the other pix.
https://www.flickr.com/photos/19089828@N00/22599339579/in/album-72157660389525577/lightbox/
regards, m
It's the steel. You typically only get hamons on shallow hardening steels such as 10xx, w2, etc. I don't think you can get one on 52100
Thanks bdb! It's just a little test knife. I've never made a puukko before. That cutting edge all the way to the handle face, and no hand guard make for a "user beware" little work knife. I'm going to sell this for belt money but I do like the look of'em.
m
52100 will produce a differential hardening line....not a hamon. See pic above ^ (Especially when you only edge quench)
