- Jun 16, 2008
hello: to start ill take a piece of pc ground O1. i OUTLINE IT AND CUT AS CLOSE TO THE fiquere as possible. Now if i dont have a grinderwhat files would i start to use to start the process. do i just file like a flat grind from the spine down. Ill have the edge measured to know how much to take off. ill also be needing a precision file guide right?Im thinking i need to be careful not to mess with the spine during this process. when i file down to desired width then i heat treat and temper?. then i switch to sand paper --60-150-220-400?. then aplly handle. tapering the handle down at the RICCOSO (?)seems to be a challenge since im not using a bolster.Am i way off. can you all give my some pointers. i dont want to use a grinder. i really want to start back with the most simple way to make a knife-thank you so much --mark
