Stoopid cool scale sanding tip
This isn't much, and it's probably in a sticky somewhere.
Sanding scales flat on a plate. I finally figured out if you cut your paper, then dump a bit of water on the plate, the paper sticks to it easily, almost without holding it, and an added bene, the dust sticks to the paper too, so it doesn't get all over the place.
That's it.
And, when you are done with a sheet, just roll it up on the plate. The wet side sticks to the dusty side to further capture the junk, and off to the trash can.
That's it.
With fine paper / say over 800 grit/ try to sand dry .Wet only back side to hold on plate ...........collect dust with magnet .On extremely fine sand paper works even better .
