- Aug 2, 2004
I just tap the tube on the blade and that usually puts enough on the surface with out having to actually squeeze any out. I know looking down a hose or gun barrel is just plain wrong
, but you can also just squeeze it untill you see it appearing the the tube nossle and then dab it on. You also can get the grease back in the tube by using the air pressure in the squeezed tube to suck it back in.....The tube isn't the best but it isn't that bad either once you get to know it.
well I am doomed to be misunderstood on this one, but that's ok!
My whole point is not that you need a bunch of grease, or that there is not enough in the tube
MY POINT IS THAT WHEN YOU SQUEEZE A NEW CRK GREASE TUBE THAT IS NOT 100% FULL, IT CAN BE HARD TO GET JUST THE TINY DAB YOU WANT OUT OF IT IN A CONTROLLED FASHION. YOU CANNOT TELL HOW MUCH GREASE IS IN THE TUBE BECAUSE IT IS NOT CLEAR, SO IF YOU ARE A GOOF LIKE ME, ALL OF A SUDDEN THERE IS A BIG BLOB ON YOUR BLADE THAT YOU CANNOT PUT BACK IN THE TUBE, SO MUST BE THROWN AWAY.
Am I yelling? Love you guys!![]()
