Straight razor patterns
Finally got my belt grinder built, and I want to try my hand at making some straight razors. I have seen a lot of pictures of the Wade and Butcher 9/8 and 8/8. Does anyone happen to have a pattern of one I could print out? I have restored quite a few vintage, but have never held a “chopper”. So not quite sure I could get the proportions right, just by looking at pics on the net.
i would really start on normal knives first...straight razors are like the formula one of knife grinding....if its not perfect its pretty much useless
i'm a straight razor collector . i have several '' choppers '' in my care . are you wanting measurements , thickness ,
type of metal , ? . unless you are incredibly well versed on straight razor making or just have a lot of metal ,
to practice with , as this is an art all to itself , I would suggest an apprenticeship under someone who can make a straight razor from start to finish .
its no overnight thing , really , not trying to scare you off , more over to encourage you to do so . learn the art .
if its measurements you want , i may be able to help you .
Peafowlguy
Yes, I was looking more for a pattern. I have many strait razors, and have restored a lot. I know grinding one will be a difficult task, but I have to start some where. Thickness and a template would be a great.
here is a for instance, if you had an 8/8 or 9/8 and it had never sharpened, then the geometry would be perfect if it has touched a stone with the spine taped then the blade moved and spine stayed the same. you need to find a geometry calculator for straight razors and go from that. 8/8 is just over 1/4 inch at the spine. I have the stenton 10/8 and a few wade barbers only none are in mint shape the stenton is closest one to mint
