Thanks a lot guys...
After mooching so many tips and tricks from the great makers here, I'm glad I found something (even though many have used it before me) to contribute back into the pot! At my former job we used to do this with steel plates up to 8"x 96" x 200" in ovens that you could drive a tractor trailer into. That's over 19 tons of warped steel!!!
I agree... if my blades are ending up warped after the noramization, something is wrong and I deal with it before I go any further.Mr. Fowler kinda hinted at something there that probably shouldn't be overlooked. If the steel is warping in the quench, there could be a little more going on and straightening it might be kinda like putting on a bandaid over a splinter. Uneven forging, uneven grinding, etc... There is a reason.
That said, I've straightened many blades after the quench but I don't like to do it. In addition to a few things I've learned from Mr. Fowler, try some advice Howard Clark gave me and I think it is okay to share here: (paraphrasing from my memory) after a few regular normalizing cycles, do a 1400 deg normalization. Straighten the blade. Do another 1400 deg normalization. Straighten. Do it over and over until the blade stops moving. It usually stays pretty straight after the quench with this little drill. This helps (with my sword blades) greatly. Especially with my damascus.
-M
I had taken some pics today with intent to post a thread on how I straighten during the temper. I found it interesting that just before dinner, I received an email from a member asking about straightening.... coincidence? (I find that happens a lot on these forums.) Whenever I'm having a problem, someone usually is posting about the very same issue. I'd like to start by saying that proper normalization and pre heat treat practices would eliminate most of your warping issues. Tweaking during an interupted quench is very handy as well. Most of the makers I see use straightening jigs after the temper and over-bend enough for the blade to take a set. I'd like to tell you that my heat treat is so good that even the most exagerated bends spring back to shape... but I'm afraid that isn't so. Some blades work out well in a straightening jig and some snap. I have also clamped the tang in a vice and used a slotted 2x4 to bend and twist the blade back to true. The sad fact is that "warp happens" and our goal is to true the blade while keeping it in one piece. That is why I felt compelled to get this thread up, as I think it could prevent some broken/scrapped blades.
I learned my lesson many years ago: I ground a fancy knife blade out of a file, finished it up with a WWI trench knife handle. The knife hung on my kitchen wall for years, then one day it snapped, all by itself hanging on the wall it broke at mid point, the front half of the blade fell on the floor. Evidently my grinding methods obviously left stress in the blade that eventually caused the blade failure. This event remains prominent in my mind.
