There are stresses in blades in the annealed condition, the hardened condition, and the hardened and tempered condition. Through every step these change, you can not stop or control them, you can minimize them.
Especialy if you forge, you’ll spend your life straightening stuff.
The best way to straighten blades after HT is to clamp the tip in the vice, pull a bend in the opposite direction, spot heat the spine on the inside to ~600-650f and repeat as necessary until the blade is straight. The surface of the heated area shrinks, which is why you heat the inside.
This method has less stress than peening and is very fast. Be carefull with pattern welded material because it can affect etching at the heated area.
Hoss
