- Sep 17, 2000
I searched around and found some good advice, but none of it was specifically for O-1. So here is my question:
I sent out seven blades for heat treat (a buddy of mine owns a big machine shop and the knives went out with a bunch of tooling he had heat treated, so it saved me money...although I was a bit worried that it wasn't a knife specific place). They all came back a little warped. Four of them I can live with and with couple passes on the grinder before I get back to working on the bevels they'll be fine. The other three are a bit longer (around seven inches or so of 5/32 O-1) and are warped enough that I'll have to try to straighten them to make them usable.
I've read clamping them so they are bent slightly opposite the warp (by using a shim at the blade tip or something similar) and putting them through a tempering cycle is the/a way to do this. Google searches have the tempering cycle between 350-400 degrees for two hours. I mainly want to make sure I do this right before I do it.
Here are the knives I got back. The three in question are the longer slender identical ones...
