Yes sir. Chef's knife. I did grind bevels pre heat treat but the stock was less than 5/32" thick. It's still 1/4" away from the edge. Hoping it will survive.Looks like auto hamon to me too
Prob left too thick before hardening at that point
Is it a kitchen knife?
Doesn't look to go to edge so should be ok but they do look ugly on a blade
1095 needs a really fast quench, parks 50 works best. I’ve quenched full thickness 1/8” stock without issue, but if your thinking of trying a different steel Pops Knife Supply just started carrying 8670 in house, it’s a high nickel carbon steel used for saw blades in industry. It is a very tough steel, about 5 times tougher than 1095 at the same hardness. I’ve experimented with it and done a few knives that I’ve left at 63hrc and it holds a great edge, it’s also a deep hardening steel so you don’t need the fast quench oil and it’s a bit more forgiving on heat treating versus 1095. There stock comes at a very fine grain and is ready to quench without thermal cycling. I hot stamp my makers mark so I thermal cycle anyway and it is easy to get a really fine grain again.Yes sir. Chef's knife. I did grind bevels pre heat treat but the stock was less than 5/32" thick. It's still 1/4" away from the edge. Hoping it will survive.
I used Park's 50 and went straight into the oil in less than a second. Who knows. I had already decided I was done using 1095 and based on your suggestion I'll try some 8670. I had read about it somewhere then forgot the steel and where I read about it(I'm going downhill fast haha). I'm pretty sure this was it though. Thanks!1095 needs a really fast quench, parks 50 works best. I’ve quenched full thickness 1/8” stock without issue, but if your thinking of trying a different steel Pops Knife Supply just started carrying 8670 in house, it’s a high nickel carbon steel used for saw blades in industry. It is a very tough steel, about 5 times tougher than 1095 at the same hardness. I’ve experimented with it and done a few knives that I’ve left at 63hrc and it holds a great edge, it’s also a deep hardening steel so you don’t need the fast quench oil and it’s a bit more forgiving on heat treating versus 1095. There stock comes at a very fine grain and is ready to quench without thermal cycling. I hot stamp my makers mark so I thermal cycle anyway and it is easy to get a really fine grain again.
Fast move from oven to oil is good thing , always . BUT you need to understand what and way is important ............In less than second for 1095 steel .......MEAN that oil must cool down steel to a certain temperature /search that/ in LESS then second , not to move blade from oven to oil in less then secondI used Park's 50 and went straight into the oil in less than a second. Who knows. I had already decided I was done using 1095 and based on your suggestion I'll try some 8670. I had read about it somewhere then forgot the steel and where I read about it(I'm going downhill fast haha). I'm pretty sure this was it though. Thanks!
Natkek parks 50 is a commercial oil over here that has an initial cooling rate of water so it is fast enough to properly quench 1095 assuming the oil was in its working range of 50-120 degrees Fahrenheit and the blade was left in the oil for atleast 5-6 seconds fully submerged and agitated to ensure a vapor jacket didn’t form. Also it’s important that there was enough oil for the size of the blade. I use 5 gallons of parks 50 and can quench a blade up to 16” long in my current container and there is enough oil to properly cool the material.Fast move from oven to oil is good thing , always . BUT you need to understand what and way is important ............In less than second for 1095 steel .......MEAN that oil must cool down steel to a certain temperature /search that/ in LESS then second , not to move blade from oven to oil in less then second![]()
That last part is interesting. i just have one gallon in a container that's just a little over a gallon. That might be part of it.Natkek parks 50 is a commercial oil over here that has an initial cooling rate of water so it is fast enough to properly quench 1095 assuming the oil was in its working range of 50-120 degrees Fahrenheit and the blade was left in the oil for atleast 5-6 seconds fully submerged and agitated to ensure a vapor jacket didn’t form. Also it’s important that there was enough oil for the size of the blade. I use 5 gallons of parks 50 and can quench a blade up to 16” long in my current container and there is enough oil to properly cool the material.
I don't see why you couldn't but with this particular knife i'll just finish it and use it in my kitchen.Is it possible to salvage this blade by re-heat treating it? I've seen a few threads about HT problems where the conclusion seems to be "throw that one away", but I always wonder about that. Why not re-do the normalization and quench and temper processes?
If warping is a concern (because of post-HT beveling), there are ways to try to straighten the blade. If the warp is unfixable, you haven't done that much more work prior to giving up on the blade. And you might salvage it.
None of this is a serious suggested solution by me - I'm far too new at this to have a meaningful opinion. It's more me wondering why I don't see this suggested more often. Maybe there's some good reason why this wouldn't work at all - if so, please let me know.
Thanks,
-Tyson
I believe the OP said he heat treated it in an even heat oven.Not sure if I missed it but was this heated in on oven or forge?
Ah, yeah I see that. It looked like the tang acted as a heat sink, typical of a 2 brick forge heat treatment. Since it was an oven, beats me! Were you able to get the whole knife handle and all in the oil, or just the blade?I believe the OP said he heat treated it in an even heat oven.
One gallon oil is enough for one blade , dimension of your container ?That last part is interesting. i just have one gallon in a container that's just a little over a gallon. That might be part of it.
All of it except between an 1/8" to 1/4" of the tang.Ah, yeah I see that. It looked like the tang acted as a heat sink, typical of a 2 brick forge heat treatment. Since it was an oven, beats me! Were you able to get the whole knife handle and all in the oil, or just the blade?
Standard heat treat. Using an Evenheat oven I put blade in at 1300 ramp as fast as poss. to 1475, soak 10 min, quench in Parks 50.Did I miss the heat treat this knife went through? Did you soak at target temp after your oven was equalized?
