- Nov 29, 2011
Hello all, this is one of my first posts in this forum, though I have greatly appreciated many of the discussions found here! I'm a knifemaker in NE Georgia that mostly makes kitchen knives out of recycled materials (gutsy, and perhaps stupid, I know ;-). I get away with it by testing every blade for a variety of characteristics and by doing my homework as best I can. Please don't try to dissuade me from using recycled steels, I am well aware of the dangers/impracticality of using recycled steel and have used a variety of them for 16 years and have personal reasons for doing so.
I use a lot of different steels, some much more frequently than others. I have a heat treat oven and a propane forge and use both for heat treatment. Honestly I prefer the forge for its flexibility when hardening a variety of different steels and get good results (small grain size, toughness, evenness of hardness, max hardness for the steel, etc) on many of the simple 10xx steels, including hyperutectoid varieties, 5160, 9260, and others- believe it or not for fun I've even used a forge to successfully heat treat 440c, but I do not recommend it! I use the oven for 52100, 440C, and other steels that are touchy about soak times.
I have a Rockwell hardness tester that I keep well-calibrated. I test every blade and iteratively temper in a home oven until each piece is to the range I want for each particular piece. Tests are done on 400 grit polished steel and in multiple locations on the blade to ensure I get a good read and to test for evenness. I also use a blade of known hardness that's very consistent as a scratch-tester, do tip-break tests on brick, cement, and twisting in a piece of oak end-grain and generally keep an eye out for "strangeness" during HT).
Which brings me to my quandary. I often use integral-tooth old large lumbermill circular saw blades for chef's knives. They're almost all different steels, but they're big enough to get 30ish knives out of and they're almost always a good blade steel when HT'd right, so they're worth the testing effort. I have two blades that I've cut into a bit that have some weird properties. First, they are sensitive to hardening temp, a tad too high and they only harden to the mid 50's HRC, just right (watch them transform) with a reasonable soak and they harden to HRC 63-64. At about 300F temper (2 hrs) they come out to a very consistent HRC 61.5 +- the 1 point tolerance of my machine. Now that's great, I can hang with that if everything else checks out, but here's the weird part, it's REALLY tough and ductile at that hardness (great in some ways, but it lacks much resilience or strength- I can correct warpage on hammer and anvil (even in very thin sections like tips <1mm), it is possible but very difficult to break in a vice (good grain structure though due to careful subcritical cycling prior to quench) and grinds like butter, but it is not resilient like 5160. AND 9260 (read pretty much exactly 5160) at HRC 60.5 can scratch it, though it can actually scratch back a little bit (weird enough huh?). The steel acts like it is at HRC 56-57, but the tester is dead-on accurate on other types of steel and on it's calibration block, (which is right at HRC 60.7, so not way off one direction or another). I just finished a blade out of it and sharpened it to approx. 15 degree 50/50 bevels to 8000 grit- VERY thin cross section (think Japanese style chef knife). I roughly and aggressively chopped through a 2x4 with no rolling or edge deformation, but it SEEMS LIKE IT SHOULD given how ductile it is. I then tried a piece of seasoned and very hard 1" thick white oak board, chopping hard crossgrain, which caused an almost imperceptible deformation after 20+ hits, so it seems to be supporting the edge relatively well for how soft it seems.
I've also had issues with some sawblade steels being too ductile to support a wafer thin edge unless they're up at HRC 63 or greater (one of my sawblades gets to HRC 65-66). They're not chippy at HRC 64 hardness either. 1095 is much more rigid at that hardness, though MUCH more brittle.
Is it possible to have steel be hard, but act soft/too ductile?
Anyone else have this or similar issues? Any ideas?
Thanks,
~Luke
Thanks,
~Luke
