The knife is
1. Blade Steel – Z-wear. German improvised version of the CPM3V steel by Crucible, very hard use steel. This steel is exotic, and very hard to work with especially with the grind Duane did.
2. Blade thickness – 4/16” thick
3. Cutting Edge – 3 2/5”
4. Dimensions – 7.3oz, 5 1/7” closed
5. Handle Material – 7075 T7 Aluminum pocket milled then anodized with type 3 mil-spec standards. Extremely high in strength but relatively low in weight, used in high stressed structural parts including aircraft, aerospace, and defense. With normal use of the tool, the handle is resistant to abrasion, erosion, and extreme heat.
6. Blade Grind – Chisel Ground by hand
7. Locking mechanism – Framelock
8. Features – Bead by bead blasted on “skateboard tape” style grit for performance grip. 3D grind yielding five sides of the blade. Signed by Duane Dwyer and demonstrated the sharpness by shaving off arm hair without artificial force(sliding down holding the knife but no force is applied). Insanely sharp, I have video of shaving off arm hair upon request.
Price : $1359 shipped(to 48 lower states, US only)
Thanks for checking us out! If you prefer email, dwl(at)ExaTactical com
