Bronco
Moderator
- Feb 25, 2000
FWIW, I have both Strider and Sebenza folders. Two Sebenzas, in fact, a large and a small. The Sebbies pretty much stick to the same old boring script. Fit and finish was perfect as purchased and has remained so throughout the ensuing decade. Cutting efficiency is very high and there's something refreshing about a manufacturer who not only encourages you to take apart their folder if you so desire, but even gives you the tool to do so.
The Strider, of course, sports a much blockier handle design than the Sebbie. That's not to say it's uncomfortable, however. In fact, I find the ergos to be more than acceptable for the majority of my purposes. The thicker blade cross section renders it less of a slicer in comparison to the Sebbie. The flip side to that is that the blade can theoretically handle tougher tasks. Unfortunately, in my experience, the handle construction and fit don't really inspire great confidence in pushing the knife to its limits. Things were fine initially. But over time, the blade no longer centers between the scales when closed. More distressing is the blade play that has developed. At this point there is no adjustment to the pivot screw possible that will both eliminate blade play and allow for smooth opening. I leave just a bit of wobble so that I can open the blade and have found that the blade is fairly stable once locked - at least good enough for routine tasks.
