- Mar 31, 2010
Some of you folks may have tried this without success and others won't care in the least. I like to lock tite my screws on and I am in Oregon so I really do like the piece of mind of not having to wory about rust under the scales.
Start with laying out this Scotch 3M green laquer tape down and covering the entire area with a layer of it.
Uploaded with ImageShack.us
Next screw the Grivory scales down tight over the top of the tape. Blurry pic but you get the idea.
trim the tape away from around the outside diameter of the grivory scales. You can see the tape in the lanyard hole. Here's the stripper I used and gloves along with the applicator brush.
I used a stick I had laying around as my scraper. This Stripper "Jasco" "Speedomatic" is just one brand with the same active ingredients. It only takes two or three minutes to eat up that Camillus epoxy coat.
This is the chemical you want to use for this because it works so fast it doesn't have the time to soak in up under the handles before you rinse it off.
