- Apr 14, 2006
Looks like a Modified Badger Attack.
Nice work on the stripping Bill, they look great :thumbup:
You are correct--It's a Modified BATAC
Excellent work Bill, they look sweeeeeeeeeet!:thumbup:
That's the stripper I used on my BWM. Works great but with the full convex of the BWM I ended up doing a lot of hand sanding also. I might try the metal polish idea, I think 1500 grit paper was as far as I went.
no, just held on by the flared tubes, in addition to the flare keeping the handle slabs
attached, they also expand against the walls of the hole in the blade tang & handle
scale, very tight fit.
I think that epoxy would be a really bad idea on a hard-use knife, because if you damage
one of the slabs it would be a bear to remove and replace if epoxy was used.
Looks great. I have a BWM that has a green blade, and I really want a satin blade so I might go this route. Thanks for the inspiration.
