- Sep 29, 2008
I would try any of the above right AFTER soaking it (not the blade) in very hot water..I mean boiling. Use a pair of oven mitts if you have to. It's simple chemistry or physics (depending on what major you are) and is a trick that I use all the time to try to loosen metal up.
Will definitely solve lock tight issues...even though this isn't th case...just FYI.
While I knew heat makes metal expand and that boiling water would loosen locktite, I never figured boiled water would be hot enough to make the metal expand enough to loosen a tight screw. Learn something new everyday, or everynight at this point.....lol.
