Sharp Minded
- Apr 6, 2020
Where can I get the etchant? I’ve searched and only came up with Radio Shack. Is it something I can get from HD or Lowe’s?
that, Sir, is genius! Can’t wait for another stripping project!
It is my personal preference to use the electrical method and the etching solution is extremely aggressive and can reduce the sharp edges. I think the proper way using electolosis would be to use a real power supply unit to dial the voltage in precisely. I used a battery charger and it was super slow but got the job done. But I have to say you can't discount the results above by VashHash. That looks really deep, super clean and beautifully squared off edgesNine volt battery, four alligator clips, two small insulated wires, Qtips and salt water and you can etch as deep as you want if the coating is still on around the Busse logo!
Be safe and do it outside do not breathe in these fumes they are Bad.
Leave it and beat it. Looks good!All stripped. Used Scotchbrite pad and 00 steel wool after. Not sure if I'll go further or leave like this.
I REALLY appreciate the help. Sorry,Robdude for jumping into your thread, but it's all good info here.
For those who do this with a power supply, what's your preferred voltage and current settings? I'd really like some guidance on this.It is my personal preference to use the electrical method and the etching solution is extremely aggressive and can reduce the sharp edges. I think the proper way using electolosis would be to use a real power supply unit to dial the voltage in precisely. I used a battery charger and it was super slow but got the job done. But I have to say you can't discount the results above by VashHash. That looks really deep, super clean and beautifully squared off edgesThat is the way you want it to turn out the way I see it.
