Well, terminology can get confusing here. A lot of people will talk about how a knife edge has "teeth". They might say that the edge looks like a "saw", or has "micro serrations". However, when you actually look at an edge under magnification, you might be surprised to discover that you can't see any teeth!
A knife edge doesn't really have "teeth", if what is meant by that term is denticulations that project out from the very edge, where the two bevels meet. There are some extremely small chips in the edge, which I guess you could call teeth, but those aren't visible at 30X magnification. In fact, it's hard to see them at 3000X magnification! Check out Juranitch's Popular Science article:
here. Scroll down to the bottom for electron mircroscope pics of an edge.
An edge might not have "teeth", but it does have "furrows".
Furrows are the little grooves on the face of the edge bevel that are created by an abrasive hone. The less abrasive the hone is, the less pronounced the furrows are. It's hard to see the furrows with your naked eye, but they're easily visible with a loupe or magnifying glass.
Furrows increase the width of the actual edge and create drag as you cut. Stropping helps burnish the edge bevels by removing these furrows. A strop is an abravise, just like any stone, but it's very, very fine. So, you could certainly also use it to remove a burr or add some convexity to an edge.
I used to use an old leather belt, sans polishing compound, for stropping. It worked pretty well, but I decided stropping wasn't for me; it was an unnecessary step in the sharpening procedure for my needs. A rougher edge seems to last longer and doesn't tend to slide through fiberous material - qualities you look for in an edge made for "using".
Cerulean
"My good reason to carry a knife is that God gave me rather weak teeth and rudimentary claws in an evolutionary trade-off." - J.K.M.
[This message has been edited by cerulean (edited 02-13-2001).]
