- Jul 13, 2011
As for video, I don't have a camera for that. The upside is, there are many good videos already out there (search Murray Carter sharpening).
By 'properly prepared', basically it comes down to making sure the edge is completely apexed (at an absolute minimum). Beyond that, the more refined (polished) the edge is made on the stones, the more effective the stropping will be at further refining & polishing the edge. I mentioned earlier, about 'degrees of sharp'; that's sort of what I was referring to. Stropping is usually done with very fine grit compound, or in the case of bare leather, EXTREMELY fine abrasives (silicates) in the leather. If your edge off the stones is very coarse, the strop can remove burrs, but you can't expect much beyond that in terms of polish or additional refinement (thinning) of the edge. For high polish, it needs to be approached in small steps, tight increments in grit progression. If the jump from one grit to the next is too wide (say, from 220 to 600 to 1000, if using wet/dry sandpaper), then the much smaller abrasives on the strop won't be very effective at removing the coarse scratches left behind. If, on the other hand, the grit sequence is tight (220/320/400/600/800/1200/1500/2000, then stropping with something like 6, 3 and 1 micron diamond paste) the bare strops will at least have a chance to really make the edge 'pop'. All of this assumes, of course, that the technique is solid (consistent angle maintained, good regulation of pressure throughout the process). Good technique trumps all, when sharpening. Bad technique will always produce bad results, regardless of which tools you use. Moral of the story: practice, practice, practice, as much as you can. And pay very close attention to all you do, while you're doing it. Use a good magnifier, under bright light, to frequently inspect the edge, as you work.
Can you give more detail about what you consider to be good technique, since you say, "Good technique trumps all." How will I even know if I'm using good technique or not?
