Cliff Stamp
BANNED
- Oct 5, 1998
I have seen this reported a few times and did some experimentation with it last night. I was using a few of the softer stainless steel knives (AUS-6A class). I intentionally created a burr by applying too much pressure on the rods. This left the edge burnished like you would find on a cabinet scraper, one side shaved smoothly, the other didn't at all..
Using a leather strop loaded with CrO I gave the knife 5 passes per side. It was now fairly blunt and would shave on neither side. I assume the burr is cracking off on the first few initial passes. It takes then another 5 per side to get the blade to where it will catch a few hairs and the progression is slow but steady from then on.
This seems to be more of an issue with low machinability and brittle steels, which would make sense, but I would want to do a lot more checking to really say there is a definate difference personally. But those stainless steels in general do tend to get negative stropping comments, where hardly anyone complaints about 52100 or similar in that regard.
It would be beneficial to have a slightly more coarse abrasive to remove the burr if this method was to be used, some SiC paper works very well, 15/5 grit, then proceed to the 0.5 micron CrO, gives a quality edge really fast. Handamerican has an excellent setup for this type of sharpening.
-Cliff
-Cliff
