Gotta get in on this one. People keep using non cutlery grade steelsto manufacture their wares, and the buying public keeps wondering why they get non cutlery grade results in the products. they buy.. The problem is "NOT" stainless type steels. Its steels that are not worth taking home. Yes the simple minded,(oops, simple carbon steels) work, because they have enough carbon in the mix to go thru the transformation from course to fine grain structure. Low carbon steel will "NOT" work. You would never dream of buying a knife if you were told it was cold rolled or low carbon.. Its
construction grade, metal. Suited to making brackets, or any number, of other mundain items. Not cutting insturments. The same applys to Stainless steels. There are Low carbon stainless, steels, and High Stain resisting steels. Do not confuse the too. they are not even closely related. aus6 and 440, 440-a, 440-b aus-8, 420, are low to medium carbon. Not able to go thru the transformation. Heck. 420, aus-6, and 440-a, arn't much better than what I use for guard material. Proper Stain resisting steel, 440-c, (The "C" stands for cutlery Grade), ATS-34, SV60, CPM440, AUS-10, /Are High carbon steels with enough other elements added to aid in Stain resistance, strength, shock resistance, and edge retention. No you can't simply stick them in a fire and beat the crap out of them, they require first class Heattreating. This will most definatly produce a superior blade.. If the edge is rolling, or buring. during sharpening, Either the steel is to low in carbon, Too soft. or the sharpening method is lacking. I've found that if a very fine diamond hone is used, there will be no burr, even on low quality steel. Yet leaving micro teeth, that will bite, and can be stroped. Stropping a Low quality, steel, with out the micro teeth will result in nothing more than a polished, bearing like edge. Might even shave a little, but won't cut well or last at all. We use this trick when going to shows, even on highcarbon. Polish the edge very fine. Shaves like a stright razor, won't cut hot butter. Customers love to shave their arms. But they no longer bleed all over my table. If they buy the knife< I litely touch it up on an ultra fine Diamond Hone. Cuts Like A Lazer! If for any reason some of you think I'm a newbie, try,
http://home.earthlink.net/~michaellovett/ Thanks Guys Oh yes, I almost forgot. Surgical Stainless. It only means that it doesn't rust or corrode at 212 degrees F.. Nothing to do with cutting at all. It's given S/S, a bad rap. for years. Should be called super Junk.
