Laredo-
There is a lot of good information here on sharpening, but let me give you the short answer as to what I would do in your case. I would buy 2 fine ceramic rods and drill 20 degree holes in a 2x4 so the rods stand up in a Y configuration. (you can buy this I think) I would get one coarse stone from the hardware store- the coarser the better. Grind the deepest bevel you can (shallowest angle to the stone) on the coarse stone by using a circular motion. Do this until you feel a burr with your fingernail along the whole edge on the opposite side. Turn the knife over and do the same thing. Someone here probably has a better idea what to do about that burr on the one side, maybe you steel it out to make your life easier. I don't, I just start sharpening with the rods, about 50 to one hundred strokes may be needed. count the strokes on each side, keeping ANGLE consistent. Once the knife is getting sharp, LIGHTEN YOUR TOUCH A LOT. If you hold a steady angle and finish with very light touches, you should get an edge that causes hair to jump off of your arm when shaved. I am not recommending you test this way this by the way, but that is what I do. I look damn silly with a bald left arm, but hey, I am not vain anymore. Maybe one way to save arm hair is to take a known sharp edge and compare the edge you are working with by cutting paper. You may need to clean metal particles out of your ceramic rods, I do this with cleanser and the palm of my hand. I dry the rod completely before sharpening. I may do this 3 times when building a new edge.
I am sure there are better ways, but for the sharpening challenged like us, this might be easiest.
This works on my Spiderco knives, which seem easy to put a good edge on. My problem is still with cheap knives, easily remedied by throwing them away I guess.
Don't shave with a knife unknown to you, I am probably outspoken on this, but I think you could conceivably get infected by blood born diseases, and some skin infections I suppose. You will not find doctors reusing prep razors in the ER from patient to patient. (I hope)
Ok, so maybe that wasn't the short answer.
-I actually hold the rod at an angle in front of a protractor, being too cheap to buy the jig and to lazy to make one. This is a dumb way because it is so hard to hold a steady angle, but I seem to need the suffering to develop my character...
