- Apr 12, 2009
No reason at all to use leather if youre using compound unless you simply want to. Personally I think it's a waste of money when flat wood, denim, very flat, thin cardboard, linen, cotton sheets, printer paper, etc work very well, are much less expensive, easy to do yourself, and easier to maintain and/or replace when loaded up.
:thumbup:
I'm also of the belief that a strop of hard-backed denim or linen is usually going to work better anyway, than the average leather-on-wood strop, leaving edges much crisper and working more aggressively to boot. I have found leather to work at it's best when using it as a hanging (barber's style) strop. Used as such, the leather is less-prone to compression under the blade, because the strop as a whole will tend to deflect away under anything but light 'skimming' pressure. Very fine edges respond well to this type of stropping; and that's generally the only time I'll favor leather over other means, if used with compound. And that's not to say a similar hanging strop of linen/canvas couldn't do just as well, used in identical fashion. But if an old or 'repurposed' leather belt is available, I think that's the best way to make use of it.
David
