I need to get one as well. There's definitely some power lost with a slippy aluminum drive wheel.Thanks, Huntsman Knife. I have found that greater tension helps, but doesn't completely stop the problem. I took a tracking wheel and epoxied a 1/2" strip of fiberglass down the center of the wheel. Then I put it on my lathe and smoothed it all up. I thought that a crown would help the tracking. It has helped some, but not completely. Maybe a rubber drive wheel would be the answer. I wonder where I can get one.
I don’t remember having to much trouble with mine when I switched over to the smaller slow down wheel, but I just went and looked and you should be able to remove it with a large gear puller. If you don’t have one check an auto part store to borrow one.Try Kroil or another penetrating oil? Or heat the wheel with a torch to see if it will expand a hair?
Yours just had the two set screws, right?I don’t remember having to much trouble with mine when I switched over to the smaller slow down wheel, but I just went and looked and you should be able to remove it with a large gear puller. If you don’t have one check an auto part store to borrow one.
Yes, I just looked at it again and I “think “ what I did was spray it with PB Blaster and used a screwdriver between the wheel and the plate steel behind it and just kept gently prying it as I turned the wheel. There’s a lot of never seize on the shaft now. It’s been quite a few years since I tackled that but I don’t believe it was to bad getting it off.Yours just had the two set screws, right?
Line up on the center of each wheel, not the edgesYou might have your drive wheel to far on the motor shaft.
Can you show photos of the tracking mechanism guts ?You lost me with that picture, here’s a picture of my Wilton’s tracking wheel with the belt tensioner and tracking socket head bolt.View attachment 2980820
