[/URL]Hay Horse, I really like your Amboya burl 110. It has the coated blade as well. Who did it for you? DM
I think what Pokt is talking about is the blade top looks to merely have softened lines on the blade flats. Causing it to still look like Buck's early hollow grinds. Which Pinnah spoke of and he attributes to Leroy. But that's merely the way they were 'all' done back then. (A modified hollow grind) In the last photo I can see the flat grind better. You could see it better on the early 300 series knifes as the grind was taken all the way to the top of the blade. The difference is sooo slight but a flat is present. Not worth a discussion over. DM
Among the hollow grinds, I prefer the older ones (70s or so) with the more rounded shoulders. They don't have that sharp line at the shoulder, which I know was a part of Remer's aesthetic vision, but I find they bind less when cutting.
Yes, sir, I believe you are correct. So this may not be the first 110 flat grind, but is still a FIRST for a (type of) flat grind in S35VN for a Buck 110.Hi, I think one flat grind 110 slipped by, the last 440C 1980.
George God bless
pinnah -
While this new copper frame 110 is obviously not a "full flat" grind, it IS a type of flat grind blade. Depending on the "expert" one may consult, most would call this a "high flat" grind.
MT_Pokt -
You stated, "There is nothing in the literature I've seen that comes with the knife that suggests it's anything other than a standard 110 hollow ground profile." If you look on the order form (picture attached), it CLEARLY STATES FLAT GRIND for the VERSION I (S35VN) option... simpler yet, if you simply look at the blade in hand, it is obviously FLAT and NOT HOLLOW GROUND. This new 110 copper frame S35VN IS a type of (for those who want to get particular) flat grind blade. If you don't believe it is flat, then buy one and see for yourself. I know the difference between hollow and flat grinds.
I was simply thrilled with my new knife and wanted to post pictures to enjoy. Can we please simply enjoy this "STUNNING BCCI Buck 110: 1st EVER w/ Copper Bolsters & Flat grind S35VN Steel! 1/100"
It is a FIRST for a flat grind in S35VN for a Buck 110.
George God bless
