stupid question about a hammer head.....
hey guys....i don't post here much but i know a maker will be able to help me.....i have like an antique meat tenderizer.....it basically looks like a hammer head with a hole in the middle.....how do i attach a piece of wood in the head....are they pressure fit or can i use epoxy......where can i het a nice long shaft of hard wood to use for the handle......i'd love to get a handle already pre-shaped and just carve the top to fit but i'm not sure if that is possible......thanks for any ideas guys....ryan
Try your local mom & pop hardware store for a pre shaped hammer handle.There are usually a bunch of sizes to choose from,pick the closest one and you can rasp it down to fit. Whatever you do dont go to home depot they will have no idea what you are talking about :D
thanks for the tip.....home depot sucks....i can never find anything there anyway....can i just use epoxy to hold the handle on.....how do guys put hammers back together if they break the handle......just epoxy?......ryan
You really should drive a metal wedge down into the hammer handle, after inserting the handle into the hammer head...may eliminate the possibility of the hammerhead coming off.
Last time I dealt with a meat tenderizer was when I used a 26oz framing hammer. Worked pretty good. I think what your looking for is a tapered handle where the head locks itself on to it. Kind of like a tomahawk haft. What shape is the eye?
If you use a normal wooden preshaped hammer handle and wedge:
Start with a pre shaped handle – they often have instructions attached- the ones I see here do anyway.
File and sand a long gentle taper so you can pound the handle into the head with a lot of force. This requires a good eye or a lot of on and off to try the fit.
While you are at it, sand it smooth to suit yourself.
Drive the handle onto the head with strong hammer blows.
Cut off the extra sticking out of the handle flush.
Drive a wedge in to the wood inside the eye to expand the wood in the eye further.
(For sale right beside the handles)
One trick often used is to drop the hammer head first into a container of oil to soak the handle for a week or so.
It will be taken up by the fibers of the wood which will swell to create a super tight fit.
It will also create a resilient handle which will not crack or vibrate as much in the hand.
Resoak in oil as required in a few years.
In your case, use a vegetable oil which will not contaminate your meat.
Other wise, boiled linseed oil is often used
If you do this oil soak, you will not want to epoxy the handle in as the oil will not let it stick.
Steve
thanks guys.....i am impatient and took matters into my own hands before i got to read all the posts!....ray-the eye is oval....i went to mom and pop's store and got a small hammer handle....i filed it down a hair so it barely fit in the eye....i loaded up the inside of the head with epoxy and on the tip of the wood...and smacked the heck out of it with a hammer....i didn't put the little metal wedge in....i forgot it and the epoxy was already dry......it seems wicked tight but we'll see i guess.......it doesn't see a whole lot of use so i think it might be ok....thanks for all the ideas....i appreciate it alot....ryan
