- Jun 25, 2001
> amazingly accurate.
> DRILL PRESS: A tall upright machine useful for suddenly snatching flat
> metal bar stock out of your hands so that it smacks you in the chest and
> flings your beer across the room, denting the freshly-painted fender
> which you had carefully set in the corner where nothing could get to it.
> WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under
> the workbench with the speed of light. Also removes fingerprints and
> hard-earned calluses from fingers in about the time it takes you to say,
> Oh sh*t.
> ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
> holes until you die of old age.
> SKILL SAW: A portable cutting tool used to make studs too short.
> PLIERS: Used to round off bolt heads. Sometimes used in the creation of
> blood-blisters.
> BELT SANDER: An electric sanding tool commonly used to convert minor
> touch-up jobs into major refinishing jobs.
> HACKSAW: One of a family of cutting tools built on the Ouija board
> principle. It transforms human energy into a crooked, unpredictable
> motion, and the more you attempt to influence its course, the more
> dismal your future becomes.
> VISE-GRIPS: Generally used after pliers to completely round off bolt
> heads. If nothing else is available, they can also be used to transfer
> intense welding heat to the palm of your hand.
> WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction
> of intense welding heat to the palm of your hand.
> OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
> objects in your shop on fire. Also handy for igniting the grease inside
> the wheel hub out of which you want to remove a bearing race.
> TABLE SAW: A large stationary power tool commonly used to launch wood
> projectiles for testing wall integrity.
> HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground
> after you have installed your new brake shoes, trapping the jack handle
> firmly under the bumper.
> EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward
> off of a trapped hydraulic jack handle.
> E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
> drill bit that snaps neatly off in bolt holes thereby ending any
> possible future use.
> BAND SAW: A large stationary power saw primarily used by most shops to
> cut good aluminum sheet into smaller pieces that more easily fit into
> the trash can after you cut on the inside of the line instead of the
> outside edge.
> TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
> everything you forgot to disconnect.
> CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
> inexplicably has an accurately machined screwdriver tip on the end
> opposite the handle.
> AVIATION METAL SNIPS: See hacksaw.
> PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids
> or for opening old-style paper-and-tin oil cans and splashing oil on
> your shirt; but can also be used, as the name implies, to strip out
> Phillips screw heads.
> STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
> convert common slotted screws into non-removable screws.
> PRY BAR: A tool used to crumple the metal surrounding that clip or
> bracket you needed to remove in order to replace a 50 cent part.
> HOSE CUTTER: A tool used to make hoses too short.
> HAMMER: Originally employed as a weapon of war, the hammer nowadays is
> used as a kind of divining rod to locate the most expensive parts
> adjacent to the object we are attempting to hit.
> MECHANICS KNIFE: Used to open and slice through the contents of
> cardboard cartons delivered to your front door; works particularly well
> on contents such as seats, vinyl records, liquids in plastic bottles,
> collector magazines , refund checks, and rubber or plastic parts ..
> Especially useful for slicing work clothes, but only while in use.
> DAMMIT TOOL: Any handy tool that you grab and throw across the garage
> while yelling DAMMIT
> at the top of your lungs. It is also, most often, the next tool that you
> will need.
> Oh sh*t.
> blood-blisters.
> outside edge.
> will need.
