I've damaged Victorinox SAK scales with high concentrations of DEET, but not sunscreen.I have read that some lotions like sunscreen have chemicals that could damage materials like plastic. Has anyone on here ever experienced issues with this?
That's interesting. I was surprised to find out that rubbing alcohol damages SAK scales as well. I rub down my knife scales with a paper towell with a bit of alcohol sometimes to get rid of the oils and stuff, I did that with the nice shiny scales of my old Wenger and it immediately dulled the scales and changed the finish a bit.I've damaged Victorinox SAK scales with high concentrations of DEET, but not sunscreen.
Uhhuh? Chemicals that turn frogs gay or skin cancer.. damn, I guess I’ll just stay inside.Considering what the chemicals in sunscreen can do to your body, I wouldn’t doubt it.
Epoxy used in G10 is of the chemically crosslinked variety. It's impervious to sunscreen chemicals. Any chemical which could harm G10 should not be put on your naked skin.G10 is epoxy/glass. Epoxy resins are usually crosslinked, and therefore very resistant to chemical attack. As noted, like all plastics, they are not immune to UV damage.
Victorinox uses Cellidor for their scales. Cellidor is a cellulose acetate butyrate thermoplastic and is not crosslinked. It is vulnerable to solvents. Get some high concentration DEET on it and you will see for yourself.
A rational voice calling from the wilderness. Frank sciences, yes he does.Epoxy used in G10 is of the chemically crosslinked variety. It's impervious to sunscreen chemicals. Any chemical which could harm G10 should not be put on your naked skin.
The term "G10" is specific to epoxy. If the laminate is not made with glass cloth and epoxy, it is not G10.G10 is nothing more than fiber glass cloth layered with resin, surfboard skins are fiber glass cloth some made with Polystyrene resin, some with Epoxy resin, never had an issue with sunscreen other than I didn't use enough or strong enough or put it on frequent enough. Now you want to talk Sunlight and UV Rays?
And also several different types of cloth.This is not the same as "Micarta" Micarta can be made with any of several resins.
I do have an example of G10 that’s a bit bleached out, presumably from prolonged UV exposure, but I bought it used so I can’t confirm.I'd like to see any example of deteriorated or decayed g-10 from anything short of deliberate abuse.
It's just not going to happen.
