Sunwayman C22CC is an inventive flashlight, which uses the 18650 battery, the two lights equipped can work as well as simultaneously. C22C comes with charging instructions and low voltage protection, full care of flashlight "heart" to make it healthy. The main light can be controlled by a button, it's easy to operate and hand feel smooth. Unique side light can be used as a corner lamp which is full of yellow ray, so it is suitable to read at night or at camping. The head of Sunwayman C22CC flashlight is designed with multi-slot to make it cool, so that effectively increase the cooling effect. The charging's design of flashlight's tail is hidden in extreme to make the whole flashlight more beautiful and easy to use. The stainless steel attack head is located in the tail, and install a quick hole, so it can be connected to universal tripods quickly to meet various function's request.
Main Parameters:
Emitter: Cree XM-L2 U2 LED(primary), Cree XP-G2 R5 LED(side)
LED Lifespan: 50,000 hours
Estimated Usage Time: 42 hours
Luminous Flux: 820 lemens
Beam Distance: 310 meters
Battery: 1 x 18650 or 2 x CR123A or 2 x 16340
Waterproof: IPX-8 (waterproof and submersible up to 2 meters)
Impact Resistant: 2 meters
Output Modes and Runtime:
● Primary Light
Turbo (820 lumens) - 3 minutes
High (510 lumens) - 2 hour and 10 minutes
Mid (130 lumens) - 10 hours
Low (35 lumens) - 42 hours
Strobe
SOS
● Side Light
High (160 lumens) - 5 hours
Mid (46 lumens) - 13 hours
Low (16 lumens) - 68 hours
Product Features:
● Main light Cree XM-L2 U2 LED, side light Cree XP-G2 R5 LED, with a lifetime of up to 50,000 hours.
● High quality metal smooth reflector for main light maintains great throw diatance and spread with an ideal beam pattern, able to generate an 820 Lumen beam that can reach over 1000 feet away.
● Special secondary side LED produces up to 160 lumens of soft white light for close-range lighting.
● Aerospace-grade aluminum body with military-grade Type-III hard anodized finish, stainless steel retaining ring on the top to prevent any ingression of water and dust.
● Ultra-clear tempered glass lens is both impact and scratch resistant.
● Single pushbutton side switch uses optical lens to access all outputs.
● Stainless steel crenulated tailcap used as glass breaker, self-defense tool.
● Tail with three feet design, also used as tripod mount for hands-free illumination.
● Use one single 18650 lithium battery or two CR123A/16340 lithium battery for constant current circuit and constant brightness.
● Micro-USB charging port underneath tailcap for recharging battery internally (18650 and 16340 only).
● LED power indicator above side switch glows when charging, flashes when fully charged.
● Inverted on the plane to be used as candle lighting.
● Precision IPX-8 waterproof design, can continue to light under 2 meters.
● Stainless steel clip, can be linked to clothing at any time, flexible and more use.
● Flashlight tail UNC 1/4'' screw hole, can be installed directly on most of the equipment used.
Applying the coupon code "SMWC22CC" when checkout on GearVita before Otc 24th, you can get this flashlight at the final price of $39.99: https://gearvita.com/sunwayman-c22cc-rechargeable-led-flashlight.html
Related products:
https://gearvita.com/sunwayman-c41ct-led-flashlight-1000lm.html
https://gearvita.com/sunwayman-g20c-tactical-led-flashlight-1000-lumens.html
Main Parameters:
● Primary Light
Strobe
SOS
● Side Light
Product Features:
Related products:
