If you're going to be carrying a flashlight everyday, you'd better make sure that it's got all of the best features available. Fortunately the Sunwayman C23C flashlight is jam packed with the best LED flashlight technology available, equipped with a CREE XM-L2 U2 LED that allows it to emit a stunning 1000 Lumens of bright white light. With a polished smooth reflector in a slim styled housing, this flashlight is capable of throwing a beam up to 203 Meters, crushing similarly sized competitors. Available in black and natural color bodies, the C23C is a perfect choice for as a light for work, home or emergency situations.
You don't have time to waste taking batteries in and out of your vital electronics, and the folks at Sunwayman recognize just how valuable your time is. With that in mind the C23C has been made capable of charging your 18650 battery right inside the light and without any fuss. The intelligent charging system detects the voltage and capacity of your individual battery and provides rapid yet safe charging. An integrated indicator lamp located under the side switch gives a clear visual cue for when the battery is charging and fully charged.
If you thought that Sunwayman was going to make a light that didn't integrate the very best construction features known to LED flashlight, you thought wrong. The C23C is constructed from high-quality aerospace-grade aluminum that is both lightweight and durable, capable of withstanding any sort of everyday bump or drop you can throw at it. A stainless steel retaining ring holds the tempered glass lens in place which protects solid state LED technology that is virtually shock proof. Additionally this light is rated IPX-6 Waterproof and is ready for use in any sort of weather condition.
Offering 1000 Lumen output in a compact body, the Sunwayman C23C is the latest in Sunwayman's line of rechargeable EDC LED flashlights. This light allows for internal recharging of 18650 batteries utilizing a micro-USB cord, a quick and easy way to power up your every day carry. Available in either black or natural coloring, this light makes a great companion for workers, emergency responders or just every day home use.
Main Parameters:
Light Source: CREE XM-L2 U2
Output Modes: Turbo, High, Mid, Low, Moon + SOS, Aviation Signal, Strobe
Maximum Output: 1000 lumens
Max Throw Distance: 208m
Impact Resistant: 2 meters
Waterproof: IPX-6
Product Features:
● CREE XM-L2 U3 LED, with a lifetime of up to 50,000 hours.
● Slightly depress the side switch to turn on/off the flashlight as well as selecting desired output mode:
- Turbo (1000 lumens, automatically lowers to High after 3 mins continuous use)
- High (580 lumens, 2 hrs )
- Mid (130 lumens, 10 hrs )
- Low (40 lumens, 35 hrs )
- Strobe, SOS, Aviation Signal
● USB charging interface, can be charged by laptop, charger baby or direct power supply.
● Constant current circuit, constant output.
● Effective range of 208 meters.
● Uses one single 18650 or two CR123A batteries.
● High quality metal smooth reflector maintains great throw distance and spread with an ideal beam pattern.
● Aerospace-grade aluminum alloy, Stainless Steel retaining ring on the top.
● Military Specification Type III- hard anodized body.
● Waterproof, in accordance with IPX-6 standard .
● Ultra-clear tempered glass lens resists scratches and impacts.
Available in black and silver color at GearVita.com, Sunwayman C23C makes a great companion for workers, emergency responders or just every day home use. Using the coupon code "SWMC23C" before 27th, spend $52.88, you can bring it home to accompany you: https://gearvita.com/sunwayman-c23c-multi-functional-flashlight-1000-lumens.html
Related products:
https://gearvita.com/olight-m2t-warrior-tactical-led-flashlight-1200lumen.html
https://gearvita.com/fenix-uc35-v2-0-usb-rechargeable-flashlight-1000-lumens.html
Main Parameters:
Waterproof: IPX-6
Product Features:
Related products:
