The Sunwayman C45CT flashlight is the powerful thrower searching flashlight. Wavy knurling design body ensures the light is easy-gripped. Charging Indicator Lamp cleverly built in the user-friendly side switch covered by sub-transparent rubber cap. The tail of the flashlight is ingeniously designed to be used as an emergency spike.
Main Parameters:
Emitter: Cree XM-L2 U3 LED
Max Output: 1000 lumens
Runtime: 60 hours
Beam Range: 450 meters
Power Supply: 1*18650 battery or 2*CR123A(16340) batteries
Light Color: Cold white
Working Voltage: 3.7V
Waterproof: IPX-8
Output Modes and Runtime:
Turbo: 1000 lumens
High: 580 lumens ( 150 mins )
Mid: 130 lumens ( 800 mins )
Low: 16 lumens ( 3600 mins )
Two Hidden Modes: Strobe and SOS
Product Features:
● High quality LED of Cree XM-L2 U3, with lifetime up to 50,000 hours.
● Powered by single 18650 battery or two CR123A(16340) batterries to provide constant current circuit.
● Max runtime up to 1600 mins, with the reflector of big diameter, Sunwayman C45CT is capable of reaching up to 450 meters effective range.
● One single switch provides access to all functions.
● Four brightness levels and two special functions available.
● Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish.
● Wavy knurling design body ensures the light is easy-gripped.
● Memory function, the last mode used will be memorized for next time use.
● USB charging system, charging indicator lamp cleverly built in the user-friendly side switch covered by sub-transparent rubber cap.
● Low-voltage indication, the circuit CPU will detect automatically when the battery voltage lowers to 2.8V and the white light will flash slowly five times and turn off to protect battery.
● Electronic reverse battery protection effectively protects the flashlight circuit.
● Indicator lamp for charging is built inside the side switch, it turns on in green and flash when it's under charging, constant green when charging finishes.
● Twisting the rear part of the tail cap leftwards to use it as an emergency spike to break glass when needed.
● Tail-stand capable, can be used as a lamp.
● Waterproof in accordance with IPX-8.
Purchase this flashlight of $49.99 on GearVita with the coupon code "SMWC45CT" when checkout, the deadline is Oct 26th: https://gearvita.com/sunwayman-c45ct-led-flashlight-1000lm.html
Related products:
https://gearvita.com/sunwayman-c41ct-led-flashlight-1000lm.html
https://gearvita.com/sunwayman-c22cc-led-flashlight-820lumens.html
Main Parameters:
Runtime: 60 hours
Waterproof: IPX-8
Turbo: 1000 lumens
Product Features:
Related products:
