I bought some Speedbonder 324 and activator a while back at the international custom cutlery exposition but haven't used it yet. It was highly recommended here. Just make sure you get the activator. I didn't know it needed it when I bought it and had to order it later.
The way I would plan on using it would be to attach liners when I had time constraints. One thing you can do to help bonding, if you're paranoid is, once the scales are glued/cured onto the scales, drill shallow holes through the liner into the inside of the scale. Then when you use G-flex or whatever to attach the scales to the tang you'll have some bonding of the liners/scales with the strong two-part G-flex epoxy. I haven't done extensive testing or anything with this idea, but it sounds completely logical to me and the knives I've done/sold have held up fine. I used G-flex not Speedbonder with this method though. Just the holes through the liners to add extra surface area for gluing the scales to the tang.
