- Aug 27, 2004
I have this little Harbor Frieght sander also and its a fine machine for the money if you ask me. I've made lockback folders from scratch using this one just to prove it could be done. In fact I carry one of them quite often.
The motor is a little weak at times but it does the job if you let the belt do the work and don't push into it too much.
What helps with mine is that I use ceramic belts on it that I get from A&H abrasives and once you put those on it it bumps up the capability of this little machine nicely and it can and does grind titanium and bar steel and hardened steel fine after that. Only thing is as has already been mentioned, the belt is really cooking on there way fast. Other than that though its not bad for the bucks.
Tracking on this thing is really better than the Kalamazoo I own in my opinon and belt change out is sure easy. I got mine for even less than this by going to the store on a sale day too so if you wait you can get it for less and no shipping by buying there if you have one local.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=2485
STR
STR
