"How long do you strop?"
Typically there is a detectable burr from the previous 320 grit belt. This is sometimes the flacid, feathery edge described in the sharpening section of David Boye's book "Step by Step Knifemaking" (highly recommended btw). Lately I've developed a light enough touch to get a burr that is not visible by eye, but detectable by "stropping" the blade down my arm and feeling the burr pull the hair. I then strop long enough to remove any feeling or sight of this burr. Under a pocket microscope (one of your hints) the edge is quite clean and no reflection can be seen at 60x. This usually takes between 10-16 total passes across the belt, alternating sides every 1 or 2 passes.
I have not used the Sharpmaker UF stones. I understand they produce a significant increase over the fine white stones in push cutting ability, and from my experience that is saying something. Anyone know the grit of "stainless" white buffing compound? I started using it after reading Boye's book, and before I heard of CrO compound. I would like to try the 1, 0.5, or 0.25 micron diamond compounds, but cant justify it until I run out of the 6x1x1 bar of stainless buffing compound.
"Edge retention is highly linked to sharpness, opposite to how often promoted. Both increase at the same time, the truely exceptionally sharp edges are also extreme at edge holding as they are almost completely free of deformation/fracture/debris."
This may explain why the Vapor had such high edge retention relative to a Kershaw Random Task in S60V (AKA CPM 440V) that was sharpened on the flats of the Sharpmaker brown medium "rods" (triangles actually, for those who havent used one). I dont think it would have beaten the Random Task, but it was headed that way with no sign of slowing down. I just ran out of cardboard, and got tired.
How do you relate the above statement to the results of the BK7 at 100 grit A/O. I am still trying to work out my course grit sharpening, but stalled after my move. I'm still working on a hair shaving edge from the 800 grit waterstone or from a 120 grit A/O belt, stretched and used in hand, not in the sander.
