super powered bandsaw
anyone know where to find a 25-50hp motor, gas powered? i'm thinking of super powering my bandsaw, by mounting using a bigger motor
. it needs to have a single drive shaft. what would the dimensions be?
[This message has been edited by magnum .44 (edited 06-08-2000).]
WOW! That's BIG! How about a Volkswagen? You'd even be able to shift gears
Jerry Hossom
www.hossom.com
[This message has been edited by GaKnife (edited 06-08-2000).]
i was thinking a 454 big block with a 950cfm holley carb.
i'm just messing around with this idea right know. i figured it would be nice for resawing wet lumber.
I know a guy with a nice race-setup chevy V8. I think it's producing somewhere over 450 hp. You could probably power a decent-sized sawmill off that. If you'r eserious, though, and could handle a few more horsepower, a 600cc 4-stroke, 4-cylinder motorcycle engine shouldn't be too hard to find. I think I might even have one available, but I don't know it's condition.
--JB
e_utopia@hotmail.com
My duckhunting buddies may just have what you need. The "little" airboat has a Chevy 454 nitrous injected, 4 bladed jobby. The "big" airboat has a 502 nitrous injected rig with four blades. You need every bit of it if you get one of these things stuck! Just think what kind of a band saw they would make!
Check out http://www.radarvideos.com for a good look at both of them!
C Wilkins
I take it you got your idea from those portable lumber mill setups ? Even the big one only has around an 8 hp engine on it. If you go clear up to 25 you might have too much power. I know I know theres no such thing. But really with that much power you could easily start having blades get caught and rather than slowing down or stopping the the drive wheel would just tear free and spin. Laying down rubber in a hot rod is one thing, I don't know if you want to try it with a bandsaw
One place to check out for small gas motors is tractor supply company ( TSC ). I think their website is www.tractorsupplyco.com They may not have them on their wewbsite , but at least here at the local store they were carrying 12hp briggs and stratton OHV gas engines. only trouble is it mounts vertically with the drive shaft coming out of the bottom of the motor.
Another place to look is anywhere that sells power equipment (chainsaws, mowers, rototillers, go carts )I don't know of any big chains for that but there has to be some kind of store fairly close to you.
It'll feel better when it stops hurting.
the biggest saw mill i saw was a a stationed saw (non-portable) with 150hp engine. maybe i'm overduing it, but it would be nice to have more horse power on the bandsaw, which doesn't take alot of 'lectric to power it. matt how hp is to much?
a 502 with nitros cuold probably cut through a 10ft. dia log lenght wise.
i was thinking of making a 3ft.x4ft. table for my bandsaw, and a sturdier stand that sits lower.
I guess HP isn't really the issue so much as speed and torque. Torque is a very good thing but you don't want so much that you twist the drive shaft off of your saw. And the thing about speed is when you start getting into larger engines, definitely when your up to the 25 hp and up range, is that their going to put out their peak power at about 3000 if not more rpm's. What you want is a fairly slow running ( same range as your bandsaw runs now) saw so that it doesn't look like you cut your wood up with a torch, that has lots of power behind it so it doesn't get bogged down.
Remember that HP is a rating of energy put out in a certain time frame. So some engines have high horsepoewer because they run at high speed, but are pretty ****ty on torque. When you look at engines, try and find the torque rating, or look for the engine that puts out its peak power at the lowest rpms. It'll also save gas, and make it run cooler.
You may want to come up with some kind of clutch to put on it to, or get an engine thats set up to idle with a flywheel so that you can pull the throttle back between cuts and have the blade stop without shutting the motor off.
In the end you should have a hell of a bandsaw.
wow! a little more than i expected. maybe i'll just stick with electric motors. anyone know a good price on a 5hp baldor, 220v single phase?
