Super Salyan (Now Mega Salyan)
My Super Salyan khukuri arrived and will forever be called (by me) as the MEGA SALYAN! When I picked it up the postage office attendant carried the package with both hands and said it was heavy. His first question was “is it car parts”. I said “no” it’s a khukuri. He was curious so we opened it up and had a look. We were both impressed with the Super Salyan.
The basic dimensions of the khukuri are O.A.L. 20.5”, 4.055” at its widest, blade length approximately 13”, 0.808” (hard to believe but it is really almost an inch) at its thickest and 2 5687 g or 5.65 LB. The circumference of the handle is 5.5” which means it is for really large hands. The handle rosewood (very nice) and as are handles on the chakma and karda. The butt cap, bolster, and wood on the handle are the best I have seen from Shop 2.
Surprisingly, the khukuri will slice paper and easily cut the tissue paper I used to remove some of the grease. I don’t know what grease H.I. is using but it sticks well and should be excellent for preventing rust if the khukuri is to be stored or shipped. It would not shave hair but will with very little effort.
The only thing I have tried it on is a piece of soft iron that Cliff Stamp had sent me. I had meant to gently tap on the iron but my control was rather poor with such a heavy khukuri. The edge was undamaged, but the iron block received some relatively deep cuts. I suspect that for me do the same amount of damage to the block with Mission MPK (it simply does not have the weight), I would need a full force swing.
I am a bit concern about the handle size. Like Yvsa I may have to reduce the size of the handle a bit. Currently I have no problems with it but I have yet to do any serious work with the Mega Salyan. I will make sure nobody is in the line of travel when I take it out to the woods. The handle was actually quite secure when I did some thrusting and chopping against air at home. I got tired very quickly since it takes quite a bit of energy to accelerate and decelerate the Mega Salyan.
The only problem I can find with the khukuri is that the cho was not very well finished. This is a very minor detail and does not bother me. The scabbard has a small but what I would consider serious problem since it affects functionality. The nails on the chakma sheath are loose and stick out so that the chakma handle is scratched. Also, with all my previous H.I. khukuri’s I could securely set the chakma and karda into their pockets. This is not the case with one of the pockets with loose nails. I will try and fix this as soon as possible with some epoxy. It is so loose that I can not hammer the nail back into place.
So far, I am extremely happy with the Mega Salyan and expect chopping performance to be in the “most excellent” category. This is provided that I can get it to move fast enough, and I have sufficient endurance. Perhaps my limit was the 22” Ang Khola. Does anyone else have a khukuri that approaches 5.65 LB?
Will
Will.
Congratulation & thank you for the prelim report - BTW, do you have a GRS? It just sound like GRS to me!
... The only problem I can find with the khukuri is that the cho was not very well finished ...
Just enhance it with a small 1/2 round shaped file & you'll get a beautifully finished Cho!
Please post your MEGA SALYAN field performance to be shared by us later on - OK?
NEPAL HO!
Mohd,
My GRS is 2 pounds, 13 ounces, and I find it too heavy for one-handed use. Best I can figure the Mega Salyan would be like taping two GRSs together! Yikes
Berk
Mohd, I have a GRS as well but it is just under 3.0 LB. I like my GRS but have not had much time to play with it. Chopping should be real interesting with both khukuri's. I'll be happy to share the results.
Kozak, I have no idea how to post pictures. Perhaps, I could email a picture of the Mega Salyan on the scale to Bill.
I still can not believe the weight. It is more not as forward weighted as the 22" Ang Khola so it feels lighter than the Ang Khola. However, a short workout with it quickly brings the weight to my attention.
While it is not as sleek as a GRS, taping two GRS together is a good description of the Mega Salyan.
The Mega Salyan is certainly not for everybody. I may have gone past my optimum weight vs performance ratio, we shall see. I'll have to be careful not to throw out my back. The Mega Salyan has a lot of momentum when it gets moving.
Will
Will, Et al:
Nice first impressions. Yours is definitely bigger than the one I have!!
A tip on perhaps fixng the loose nails in the scabbard.
try a pair of channel locks and squeeze the nails back into place.
That works for me most of the time when I have had that problem.
If that doesn't work I remove the nails and glue the leather keepers in place.
When I got my GRS I removed both of he leather keeers and with thinner leather put 3 keepers in their place. That let me put in the original karda and chakma as well as a Kumar Karda. It makes for a nice all around carry knife that way if a person isn't going to far.
>>>>---¥vsa---->®
The hardy adventurer just drank from a stream he thought was pure glacier fed water not knowing that upstream was being used by a herd of yaks as a giant bidet.
I said he was hardy, not smart.:-)
Khukuri FAQ
Oy Vey! Sumo ( my super salyan ) is now the runt of the litter at only 4 lbs.?
THANKS Uncle Bill for sending me the Mega Salyan. My back is still quite strong so I expect to use it for a few years yet. In all honesty I think this one is my limit for weight.
I suspect it will be scarry to see someone in action that can handle a Mega Salyan like a 15" Ang Khola. There may be environmental laws against it if such an individual is found.
An intersting aside. In a debate of chain saw vs axe, one of my co-workers sided with a properly made axe if the tree is not very large. He sited a foresty worker who could sink an axe heat into a tree. As a result a fair size tree could be taken down in a few quick wacks. I can't verify the story and certainly can not duplicate it.
Will
Uncle Bill, I have to ask, was Sher Bahadur Bishwakarma the maker of Will's Mega Salyan? If not, I'd like to see what he'd make for a Mega Salyan....
Just kidding!
Harry
At six pounds, the Kora's heavier, but it isn't a khukuri, so it doesn't count.
Hi All,
I'm still sorry that I missed out on those knives
I'd sure like to have one of those with about a 10" handle, yah.... so it could be used conviently with one or two hands.
Dan
