A couple passes on my strops (covered in dia-paste) gets the keenness right back
I believe you-and to a greater degree than the steel I pictured. But, the steel fits on my key chain
Maybe you misinterpreted what I wrote, because you agree with what I said in the first 7 sentences of your post. There is a difference, but the blades need to be identical in everything else, but the type of steel, for the performance differences to be noticeable.
Would you care to explain how M390 will more double the performance of S30V?
It takes more than random use to reach a conclusion. And cardboard is a very variable medium. Here is a report I did on running side-by-side comparisons cutting manila rope. If you run a search of the testing forum for threads I started, you will find that I did a lot of testing before reaching conclusions.
http://www.bladeforums.com/forums/showthread.php/792540-Comparison-of-CPM-M4-HC-ZDP-189-M390-and-S30V-edge-retention
The other downside is that it does take significantly longer to resharpen, and if I don't finish the edge by stropping with diamond, it never gets really that sharp. Anything other than diamond leaves an incomplete edge. Perhaps other super steel grades are better?
Shape is less important when you cut rope. Once cut, the strands of rope pull away.
That is true. I prefer blades that are more forgiving (will roll or flatten, instead of chip), as in real world use, they are easier to maintain, and are more resistant to inadvertent abuse.
I value edge holding over ease of sharpening as it doesnt make sense to me that you would give up the functionality of a knife so you can stick with inferior sharpening tools
....I value edge holding over ease of sharpening as it doesnt make sense to me that you would give up the functionality of a knife so you can stick with inferior sharpening tools
I dunno about rope but IME blade shape makes a huge difference. A curved blade will deliver more PSI on the cut because the contact is focused across a smaller portion of the blade compared to a straight blade. This is why IMO spydercos rank so high on these tests. How the blade presents itself(handle to blade orientation) also makes a difference. I'm moving further away from knives with a flat portion to ones that have gradual curves throughout. YMMV
Very true. But blade shape is matched to the cutting task, which is the larger issue.
Eliminating variables is illuminating but doesn't lead to easy generalizations. Cutting situations differ and each one is optimized differently.
To me the quest for a super steel is driven primarily by the fear and absence of sharpening skills. Make people comfortable in maintaining their tools and the longer-lived edge selling point become largely moot. High performance steels have become the Ginsu knives of our generation, the average guy hears the hype and expects to never have to sharpen the thing.
Remember the Ginsu TV ads?:
https://www.youtube.com/watch?v=6wzULnlHr8w
https://www.youtube.com/watch?v=QUarASqrVnY
https://www.youtube.com/watch?v=pde0aOM-lds
n2s
n2s
