Remember, you have to used the thinned cyanoacrylate (not the common store Super Glue). Pop's sells a nice mix although I've seen the odorless (a nice factor) at Texas Knife but never used it. I just flow it down the scales from the ricasso to butt. Use your finger nail to chip it off the pins or tang after sanding with 400 / 600. Comes right off. And yes, latex gloves are a MUST!!!!
The thinned out stuff penetrates better into the cracks, crevices and pores. Store stuff is thick and never does more than just the very top surface. If this is all you really need, then it will work. If you do mammoth or something that needs deeper penetration to "hold it together" then the thin CA is the best.Why is this type necessary? I am new to this, but have used the common store super glue twice on bone scales and been very happy with the results. I have just sanded to 600 grit, applied glue with latex gloved finger, sanded back to 600 then up to 1500, and then buffed. It has looked good, but is there going to be a problem down the line? Man, I hope not.
-Mike
Odorless cyanoacrylate in thin layers will not foam, turn white and is clear when hardened. You can build up several layers of very quickly using odorless cyanoacrylate and accelerant.And however you go about this, don't use the accelerator spray (I think it's mostly freon). It makes the CA glue foam, heat up, and discolor. Great for...well, it really isn't great for anything except making the glue dry faster.
We use several gallons of odorless cyanoacrylate every year.
