Something is not clear to me here, do you pour the glue IN the wound or put the sides of the cut together and put the glue on the top?
Glue on top is what I do. Just hold the two flaps together and apply a little.
What do you guys think about cleaning with simple soap and water vs other methods? When I started road biking alot I crashed prety hard at a race and the EMT that patched me up just used a simple salt water spray in a can. Then a hydro bandage with some clear sticky film applied on top of that. I was good to go and the thing stayd on the whole race. He said that for most cuts and scrapes the simple salt water or mild soapy water and a clean rinse are all you want to use. Something about the other methods (peroxise, iodine etc.) killing just as many good bacteria as bad. and adding days onto the healing cycle
Uhhhhh, no they don't assuming you mean doctors.Docters use it all the time.
I am a fan of glue when the injury is in a high use area and youre remote. Fingers, toes or other flexible area. Especially when you may have to expose the area to muck that traditional bandage methods wont keep out. In my experience, you have to apply the glue several times, its not a for sure method of wound closure.
It all depends on how mucked up the wound is. I'm surprised your wound wasn't embedded with asphalt, rocks, and dirt. A wound like that is worse, because it needs to be scrubbed (Yes I mean scrubbed) with a pad or something coarse that will lift that dirt out of there. It is not a pleasant experience. If your wound is generally clean, just wash it, and put an antibiotic ointment on it and bandage it. Piece of cake!!!
Jeff
the blood will push everything out.
Cleaning a wound with alcohol is not ideal, as it also kills the flesh. Also, regular Superglue is not the same as medical grade cyanoacrolyte. Besides the sterility thing, and biocomp testing, the solvent that is used in it is different. The solvent in regular super glue is not good for the wound. I am not a doc, or play one on tv, but I am an engineer in the medical device field. Just sayin'.
