- Feb 25, 2001
After reading Anthonys now infamous "Crapshoot" thread, I have a question that may be worthy of its own little thread. Are custom folders functionally inferior to the folders of large production companies? Im not trying to knock the exceptional makers in this industry, but can they really compete with the top production companies in terms of functionality and reliability?
Lets say that a top production company comes up with a new folder concept. They work over the initial design, and then perhaps have an engineer looks things over. The engineer points out possible design flaws and makes recommendations. Changes are made. Then they make a prototype to get a working model. If all looks well, a smart guy suggests the proper materials and heat treatments, and further prototypes are made. These prototypes are testing to destruction, and further refinements are made. When all of the initial work is finished, which could involve a whole series of prototypes, the company develops production procedures around tolerances that must be held for each part. A first manufacturing run is done, and the knife goes to market. Customer feedback is collected from the first run and changes are made to further refine the design. Each run becomes more reliable and consistent. To top it off, the most successful elements of the design and manufacturing process are used on the next new model folder. This leads to a whole line of beautifully functional folders.
Do the custom makers have the proper engineering degrees to design and execute a strong and safe lock? Does the makers quality control process properly guarantee a low rate of part failures? Is the blade of a custom knife properly tested for cutting ability without the expensive machine to test it?
You obviously dont get exactly what you want with a production knife. The blade shape or grind may not exactly be what you want. The handle material may not be exotic or beautiful. Forget file work under most circumstances. Fit and finish may not be your bag of tea on a production folder. But in sheer terms of functionality and reliability, can a custom maker even compete with a knowledge and collective experience of a large production company?
To tell you the truth, I dont know the answer. Im not a custom maker, and I dont even own a custom folder. Id like to get a good custom folder, but Im very hesitant in finding out the hard way.
