Both are very similar - basically the same weight , same lenght, almost the same steel, same handle material -
It's said that the japanese VG10 steel is very slightly better than the american 154CM.
MANIX 2 is just a bit heavier - 3g is nothing - and also has a slightly longer cutting edge , extra 2mm .
Other than that the knives are quite similar ; lock is different though .
As a result ... why the price difference of over 60% when both knives should cost the same or be priced very very close ? Maybe I am missing something ...
I must admitt that I love the MANIX 2 - this is why I have recently purchased some sprint runs - but I can't wait for the SUPERLEAF - which is to be received pretty soon but I got it for slightly more than a regular MANIX 2 -
MANIX 2 specs :
length overall 8 in. (203 mm) blade length 3 3/8 in. (86 mm) blade steel 154CM
length closed 4 5/8 in. (117 mm) cutting edge 2 7/8 in. (73 mm) weight 5 oz. (143 g)
hole diameter 9/16 in. (14 mm) blade thickness 1/8 in. (3 mm) handle material G-10
SUPERLEAF specs :
length overall 7 15/16 in. (202 mm) blade length 3 7/16 in. (87 mm) blade steel VG-10
length closed 4 11/16 in. (119 mm) cutting edge 2 13/16 in. (71 mm) weight 4.7 oz. (140 g)
hole diameter 9/16 in. (14 mm) blade thickness 5/32 in. (4 mm) handle material G-10
MANIX 2 specs :
SUPERLEAF specs :
