SureFire 6PL-BK & FM35
Feedback: +26 / =0 / -0
Both are NEW and in sealed packages from the factory
#1.) 6P LED - BLACK
Compact (pocket sized), high-intensity LED flashlight for tactical, outdoor, and general use. Puts out a smooth, brilliant beam with four times the light of a larger two-D-cell flashlight—bright enough to temporarily blind and disorient a person by impairing his night-adapted vision. And it continues producing useful light levels for an impressive 11 hours on a single set of batteries. Lightweight, strong, aerospace-grade aluminum body resists crushing or bending. Small size, high output, and extended runtime make it perfect for self-defense, camping and backpacking, emergency/disaster-preparedness kits, or everyday carry.
FEATURES
* Virtually indestructible light emitting diode has no filament to burn out or break; lasts for thousands of hours
* Precision reflector creates smooth beam without spots or rings
* Rugged aerospace-grade aluminum body, Type II anodized in glossy black
* Coated Pyrex® window protects LED and reflector while maximizing light transmission
* O-ring sealed; weatherproof
* Tailcap switch: press for momentary-on, twist for constant-on
* Patented switch lockout prevents accidental activation
* Batteries included
#2.) FM35 is a Red Filter for flashlights with 1.25" diameter bezel
The FM35 Red Filter produces a smooth beam of red light that will not degrade night vision as white light would. Hunters use the red filter to avoid spooking game during predawn hours - deer see poorly in the red color spectrum. The filter is also useful for close range, non-tactical applications - such as map reading -- as it reduces the intensity of light output. Applying thumb pressure to the locking tab releases the cover; a spring mechanism keeps the open cover out of the way by holding it flat against the flashlight. A cam-locking lever keeps the entire unit securely attached to the flashlight.
FEATURES
# Fits 1.25" bezels, including Z2, C2, C3, G2Z, G2, 6P, 9P
# Cam-locking lever keeps filter securely attached to flashlight
# Provides secondary protection to flashlight lens window
# Does not impair night vision
I will not break up the set at this time
BOTH shipped to a USA address $100 with USPS money order
ADD 5% for PayPal
LINK IMAGES & DESCRIPTIONS AT SUREFIRE WWW SITE
