Hi everyone, just like to let you know that we have Surefire in stock and ready to ship. Right now we are offering a Free $6.95 Shipping Credit on all our Surefire Flashlights.
Surefire E1E Executive Elite $79.00
Surefire E1E Executive Elite flashlight with a special incadescent lamp assembly and micro-textured reflector for a smooth beam. Body and bezel are made with hard-anodized aerospace grade aluminum. Impact resistant and weatherproof O ring and gasket sealed. The tailcap switch can be pressed for momentary on and pressed further to click for constant on. Stainless steel pocket clip has multiple carry options. Includes one CR123A lithium batteries. Made in USA.
Surefire E2E Executive Elite $105.00
Surefire E2E Executive Elite flashlight with a special incadescent lamp assembly and micro-textured reflector for a smooth beam. Body and bezel are made with hard-anodized aerospace grade aluminum. Impact resistant and weatherproof O ring and gasket sealed. The tailcap switch can be pressed for momentary on and pressed further to click for constant on. Stainless steel pocket clip has multiple carry options. Includes two CR123A lithium batteries. Made in USA.
Surefire E1L Outdoorsman LED $139.00
Surefire E1L Outdoorsman flashlight with a power regulated LED emitter and TIR (Total Internal Reflection) lens. Body and bezel are made with hard-anodized aerospace grade aluminum. Impact resistant and weatherproof O ring and gasket sealed. The tailcap switch can be pressed for momentary on low and pressed further to click for constant on low. For higher power, return the light to off and press for momentary on high or click for constant on high. Stainless steel pocket clip has multiple carry options. Includes one CR123A lithium batteries. Made in USA.
Surefire E2L Outdoorsman LED $149.00
Surefire E2L Outdoorsman flashlight with a power regulated LED emitter and TIR (Total Internal Reflection) lens. Body and bezel are made with hard-anodized aerospace grade aluminum. Impact resistant and weatherproof O ring and gasket sealed. The tailcap switch can be pressed for momentary on low and pressed further to click for constant on low. For higher power, return the light to off and press for momentary on high or click for constant on high. Stainless steel pocket clip has multiple carry options. Includes two CR123A lithium batteries. Made in USA.
Surefire G2 LED Black $69.00
Surefire G2 LED flashlight with a power regulated LED emitter and micro-textured reflector for smooth beam. Body made with extremely tough, corrosion proof black Nitrolon polymer and a machined aluminum bezel. Impact resistant and weatherproof O ring and gasket sealed. The tactical tailcap switch can be pressed for momentary on or twisted for constant on. Includes two CR123A lithium batteries. Also available in OD green and Tan. Made in USA.
Surefire G2 Nitrolon Black $39.00
Surefire G2 Nitrolon flashlight with a high intensity SureFire incadescent lamp and micro-textured reflector for smooth beam. Body and bezel is made with extremely tough, corrosion proof black Nitrolon polymer. Impact resistant and weatherproof O ring and gasket sealed. The tactical tailcap switch can be pressed for momentary on or twisted for constant on. Includes two CR123A lithium batteries. Also available in Yellow, OD green and Tan. Made in USA.
Surefire G3 LED Black $92.00
Surefire G3 LED flashlight with a power regulated LED emitter and micro-textured reflector for smooth beam. Body made with extremely tough, corrosion proof black Nitrolon polymer and a machined aluminum bezel. Impact resistant and weatherproof O ring and gasket sealed. The tactical tailcap switch can be pressed for momentary on or twisted for constant on. Includes three CR123A lithium batteries. Made in USA.
Surefire L1 LumaMax LED $159.00
Surefire L1 LumaMax flashlight with a dual output LED and TIR (Total Internal Reflection) lens. Mil-Spec hard anodized aerospace aluminum body. Impact resistant and weatherproof O ring and gasket sealed. The L1 LumaMax flashlight has two output levels with a 10 lumen low level for longer run time and a 65 lumen high level. Press the dual-output tailcap click switch for momentary on low and push further for momentary on high, or twist the tailcap for constant on. Stainless steel pocket clip has multiple carry options. Includes one CR123A lithium batteries. Made in USA.
Surefire LX2 LumaMax $195.00
Surefire LX2 LumaMax flashlight with a microprocessor controlled LED emitter and TIR (Total Internal Reflection) lens. Smooth fluted body made with hard-anodized aerospace grade aluminum. Impact resistant and weatherproof O ring and gasket sealed. Dual-stage output for a high and low setting. The dual stages can be reached by pressing the pushbutton tailcap for momentary on low bean, press further for momentary on high beam, twist for constant on low beam, twist further for constant on high beam. Stainless steel two way pocket clip for head up or head down carry. Includes two CR123A lithium batteries. Made in USA.
