SureFire Lumamax LX2 ((SOLD))
Feedback: +22 / =0 / -0
Good as new!! Cared for and Rarely Used...
SOLD
Specifications
Output / Runtime -- White Light
High 200.0 lumens / 2.0 hours*
Low 15.0 lumens / 47.0 hours
Tactical Runtime* 2.0 hours
Length 5.40 inches
Bezel Diameter 1.00 inch
Weight w/Batteries 4.2 ounces
Batteries 2 123A (included)
*Runtime (at highest setting for multiple-output flashlights) until output drops below 50 lumens
Description
LX2-HA-WH
The LX2 is a compact dual-output flashlight featuring a virtually indestructible power-regulated LED emitter, a Total Internal Reflection (TIR) lens, and a smooth fluted body design that takes it easy on clothing. The LX2's tactically-correct two-stage pushbutton tailcap switch lets you instantly select output level: press for a momentary-on 15-lumen long-runtime low beam suitable for general night use or close work; press further for a momentary-on 200-lumen high beam—ten times the light of a big two-D-cell flashlight; twist for constant-on low beam, twist further for constant-on high beam.
[NSN: 6230-01-522-6610]
Features
Virtually indestructible LED emitter regulated to maximize output and runtime
Two output levels—high for maximum light, low for extended runtime
TIR lens produces tight beam with enough surround light for peripheral vision
Coated tempered window resists impact, maximizes light
High-strength aerospace aluminum body, Mil-Spec hard-anodized for extreme durability
Two-stage tactical tailcap switch—press for momentary-on low, press further for high, twist for constant-on at either level
Two-way clip permits light to be carried bezel up or down
Weatherproof O-ring and gasket sealing
Includes high-energy 123A batteries with 10-year shelf life
